Standing Rigging
Standing Rigging
Postby Guest » Wed Nov 06, 2002 3:02 pm
Recently purchased a vintage 1959 boat from an estate. Boat is pretty much complete, but no turnbuckles were with the rigging. Did the shrouds, and stay attach directly to chain plates with clevis pins, or were tunbuckles used. If so, any idea as to length for shrouds, or what was used for the forestay connection?
(May sound like silly question, but section of mast from about deck level down to keel maststep is also missing. I plan to make into a hinge arrangement when I can locate something for the missing piece of mast. I plan to careen the boat on to its side, at which time i can better fiddle with the mast in horizontal to get best length of new mast extension.)
John Hampe (ghampe-at-rcn.com)
Postby Bob Hunkins » Wed Nov 06, 2002 4:56 pm
John,
Congrats on getting one of the original Day Sailers! The original boats had keel-stepped masts, so what you may have is a full keel-stepped mast. The length of a keel-stepped mast is about 24'. A deck-stepped mast would be about 22'. The older boats had what amounted to a jack under the mast. It's a large knurled brass disk, perhaps 3" in diameter and about 3/4" thick that threads onto a brass threaded circular post. This post fits into a hole on the keelson inside the cuddy directly below the partner hole. The mast rests on the disk. The shrouds and forestay are attached to the chain plates, and the disk is turned on the threads moving the disk and mast up. This will tension the shrouds.
I may be in the minority on this forum, but I'd suggest not converting to a deck-stepped mast. I don't know how to explain it yet, but converting from a keel-stepped mast to a deck-stepped mast will reduce the performance of the boat. If you have one of the three-digit hulls, then you've got a boat that many in the class association prize. I don't know if I believe it personally, but many say those boats are the fastest. I personally think it's because the people who own those boats have had them a long time and are excellent sailors. In any event, I think it would be a shame to reduce the performance of the boat.
Once you know how to step a keel-stepped mast it's not that hard to do. I've been planning to document the process with some photos. It does take two people, which is a disadvantage for single-handers, unless you can keep the boat stored somewhere with the mast stepped. Sailing the boat with someone else is a lot more fun than sailing it by yourself, anyway.
If you are near a Day Sailer Fleet, find them and go talk to them - Several people in that fleet will be glad to help out. You can find the fleets on Day Sailer Association web page.
http://forum.daysailer.org/fleets2.html
Call the Regional Vice President and have them put you in touch with the nearest fleet.
If you have any problems finding someone, call me. I'm the Day Sailer Class Association Executive Vice President.
(281) 559-2167
Best wishes, and enjoy your new boat!
Bob Hunkins
Site Admin
Postby Guest » Tue Nov 12, 2002 5:06 pm
I used to always have someone help me step my keel stepped mast. After some practice and some encouragement from another DS owner on this web site I tried it by myself. Standing on the boat on the trailer, I find the balance point on the mast, and can stand it up on the ground, pick it up and put it through the partner, and climb under the cutty, and put the foot on the step. Pretty quickly and fairly easily.
Barry (Bfk-at-sandiego.gov)
Postby Guest » Wed Nov 13, 2002 12:53 pm
Bob,
Thanks for explaining the jack at the bottom of the mast. I just had to replace a parted shroud and was kicking myself for not considering turnbuckles at the ends.
Rolias, Sail No. 795
Steve Link (sjlink502-at-aol.com)
Postby Guest » Wed Nov 13, 2002 2:00 pm
Turnbuckles, and if your rigging is old, consider upgrading to 3/16" from the stock 1/8" while you've got her out on dry land. Call Rudy at D&R (link from homepage), and he'll set you up.
Congrats and welcome to the family.
Tom (tbeames65-at-cs.com)
