by Bob Hunkins » Wed Nov 16, 2005 5:49 pm
My solution to the water problem is I put an inspection port in the bow tank forward under the cuddy.
Every so often I check it so see if there is any water there and I sponge it out. Surprise doesn't take on too much. I also have two inspection ports in the seat recesses that I put there when I installed my mid boom traveller, which I look into occasionally. I think any water that gets in there will go forward when the trailer nose is lowered as far as possible.
Whenever I trailer the boat somewhere I try to open these ports to help dry out the interior. When I went to California this last summer for nationals, the boat had lost a considerable bit of weight from being dried out in the desert. I'm sureit has gained it back due to being sailed, and the humid environment here at home.
When I keep her in storage for a long time and don't use her, I also open the inspection ports to allow moisture to evaporate more readily.
In general the Spindrift boats are inferior for racing to the ODay's and Mclaughlin, and Rebels, but they can still be used, in my opinion. It depends on the conditions you sail in, how competitive you want to be, etc. The usual sailing things.
Every class probably has these kinds of problems. The J/22s for instance have boats whose keels are not as far forward as they ought to be so they actually build the keel up on the leading edge and grind it away on the trailing edge. Now that's expensive.
I capcised this boat once, a while ago, and she did take on water between the hulls and liner. Since then, I've added flotation to the inside using pool noodles. I don't know how she would react to being capcised again, but I expect there are some ways for water to get inside. I still need to investigate how to find any leaks.
Bob Hunkins
#11750, "Surprise"
San Leon, Texas
