Howdy to All,
Wonderful site here; have been lurking for a while now. We are the proud new owners of a '68 DS-I (I'll get the nbrs as soon as I crawl back into her). She had been stored in a barn for quite some time, dusty original cover (original almost everything actually). Sails (to windward) like a pig however, as the wife luff on the jib has taken a curly set which cannot be straightened - the wire section of the halyard is too long which means that the eye on the rope section stops at the mast-head sheave before the jib is set.
Oh well...great little boat tho. I've stripped and varnished the coamings, buffed out the hull and deck and will get to work on the floorboards soon enough. I do have a few questions, if ya'll would.
Rig tension? I've read suggestions ranging from hand tight all the way up to cranking the mast forward with the trailer winch. Help??? btw this is a cuddy top set up.
The standard aft traveler is a nice set-up, but seems a bit "soft" to me. I really like Phil R's rig and will probably do the switch - has anyone else done so? Can you share your impressions and comparisons?
Would 1/4" StaSet do the job for both halyards?
I'd like a rig a down haul for the jib. Does anyone have a tasty arrangement to share? Ditto for a main out haul.
Thanks to all for the great reading. The boat must yet go through a re-naming ritual so I don't yet dare write the new name out. Are pink lipstick, nakedness and alcohol still involved in the ritual?
Can you say Oklahoma winds?
Kai
