In light of discussions about crutches and travelers I am posting some pics.
Jamm Session and its primary tow vehicle. Proof an SUV is not needed.
Close up of the aft mast crutch. High enough to clear the afterdeck 1/4 inch stainless steel bolts and locknuts for the pinions. Pressure treated 2x4.
The forward mast crutch. The ball end bungees work very well to keep the stay and shrouds tight. High enough and aft enough not to interfere with opening the hatch of a Dodge Caravan.
The bungee for the tiller keeper is attached to 3" cleats screwed into the carlin under the afterdeck. Note the line fore and aft amidships to support the tarp.
The jam cleat for the tiller keeper. Lifting the bungee over the tapered end (which faces forward) is enough in light air, looping over the aft tail of the cleat makes it secure.
A slightly modified version of the traveller on Lollipop. I use a simple cleat which also serves as a fairlead. Cheap and effective. Also the cleat serves for a line run forward to the halyard cleats to support the tarp.
What I believe is an original mast crutch. All of Jamm Session's wood seems to be original. The coamings were never cut. There is no paint topsides. It is, in all fairness, a lousy design for a crutch because it limits the movement of the tiller. It was used as a boom crutch by the previous owner, and a lousy boom crutch it is too. Same reason. I will continue to use it only till I put on a topping lift.
Enjoy
Dan
