Hello:
I've been reading this forum for a couple of weeks now and just purchased a 1967 DS1. I sailed as a kid in the family's Folboat and a Sunfish, but hadn't been out in 30 years. I've had the boat out 3 times now, and she handles quite well I think. The kids love it (as does my wife) and that's what it's all about.
Anyhow, the boat needs some work, and I'm hoping for maybe some pointers. The biggest problem I've got to deal with are open cracks at the hull and bench joint: one on the aft end of the starboard bench, and one on the bow end of the port bench. I suspect that the cracks have developed as a result of poor bunk position on the trailer. The bunks appear to be positioned too far inboard and the outer edge of the hull is sagging when viewed from below. Both of the cracked bench edges have lifted from the inside surface of the hull. I know this boat sat for quite awhile as the previous owner dropped the mast and broke his arm in the process. He apparently didn't want to have anything to do with the boat after that.
So my first question is, where should the bunks be properly located, and how long should they be? Mine appear to be 2x4x4 feet long.
Secondly, has anyone else experienced this problem? If so, could you give me some repair pointers?
Next (sorry, I'll limit myself to one more question), after cleaning the boat out, I found it to be remarkably clean although in need of a new paint job. Climbing up into the bow I found a hole in the keel section and felt soggy foam core and water in the hole. Should I be concerned about this?
Sincerely,
Wyatt
