mast support for trailering
Fri Sep 05, 2008 9:44 am
by navahoIII
Hi guys,
Aside from using life jackets for cushioning and an elaborate (and ever-changing) system of ropes, bungee cords and tie downs, is there anything on the market that is simple, easy to set up, and holds the mast (& boom) securely in place for trailering?
Wishful thinking?...
Fri Sep 05, 2008 1:24 pm
by Baysailer
You could always fabricate something similar but these look pretty cheap and will do the job nicely.
http://www.ahoycaptain.com/shop/tx_aftmast.html
http://www.ahoycaptain.com/shop/tx_deckmnt.html
I always put the boom in the boat.
Fred
Fri Sep 05, 2008 10:02 pm
by algonquin
What ?? You mean you actually take the mast down for trailering
Sat Sep 06, 2008 12:57 am
NavahoIII, if you don't want to spend as much, just get a set of pintles and attach them to a board of the desired height w/ a generous notch at the top. That's the setup that came with my boat and it's served well.
So do I - but now I'm curious: where do you stow it? On the floor, on a bench?
Sat Sep 06, 2008 1:31 pm
by Baysailer
Just looked since I'm heading out for a sail and the back of the boom is on the transom floor while the front half of the boom rests on the thwart. One note of little matter I leave the main sheet setup on the boom. Either lazy or efficient, your call. My votes on lazy.
Fred
Sat Sep 06, 2008 3:27 pm
Leaving the sheet up, sounds like one less thing to do. I've been looking for ways to shave time from setup/teardown - not just from lazyness, but from the desire to spend more time on the water than on the ramp
FWIW I tie the boom to the thwart with a small fender as buffer and wedge the other end between seat and coaming using some cushions.
Mon Sep 08, 2008 9:38 am
by navahoIII
Thanks all, and for the links, Baysailer.
Mon Sep 08, 2008 2:17 pm
by hales
I use a set of 3 supports which are all made from simple 2 x 4 construction. The one on the stern is supported by the rudder mounts, one in the middle sits above the centerboard, and then one mounted to the trailer ahead of the bow. I can send you a photo if you want one. It appears all of this stuff is pretty common hardware goods. Fortunately, it came with the boat.
