My better half bought a DS I and I need maintenance advice
I can't believe we drove it 50 miles on a trailer so rusted that pieces were flying off down the road. But it is now safely in water and am disassembling the trailer and looking for a used one to replace it.
We were very lucky indeed!
I'm wondering the following and any advice is helpful!
The sails look to me like they are blown, especially the main. The last foot just hangs, there are no reefing points to pull it in some, so other than buying new sails what can I do? I've tightened it all it can. Is taking them to a sailmaker to recut worth it? Its unfortunate because otherwise they are in good condition. It doesn't point worth a darn.
The centerboard house has a couple holes on each side near the top that look machine made. They spout water when moving. I'm wondering if this is for some type of pin to hold the cb up when trailering?
The tow hitch ring was very loose and upon inspection the bolt was actually bent. I've replaced it with a rubber gasket on the outside and tightened it up. Any other ideas are welcome.
The mast hole on the deck has been cracked and repaired many times for the obvious reasons. I think this is the only downer about the boat, that mast is so tall and unwieldy. We've managed (with great back strain) to step the mast without putting pressure on the hole by up-righting it in the boat and lifting it straight up and down into the hole. I would like to be able to use the hole but fearful that additional pressure will crack it. Before I start repair would love to know of anyone's attempt to strengthen this area enough to use it.
The rigging does not have turnbuckles. Will I need to re-rig the mast in order to install these?
I think that's it for now. I'm looking forward to cleaning it up and getting some sailing in before winter starts!
Thanks for the forum. It's been a great resource.
Yona
Yona
