I have a fairly old Daysailer that I am trying to determine the approximate year of manufacture for. The serial number plate was removed sometine in the past and the molded in hull number is unreadable.
My boat has wooden seats, a "double transom" (for floatation I suppose) with a 1 inch drain into the cockpit, an external outboard mount, the deck is molded to look like planking, the gunwales have cam cleats mounted on small blocks and there are jam cleats in the gunwale itself. There is also a small air filled floatation chamber in the bow. The halyards are rope,
and are routed internally in the mast.
Thanks for any information any one may have.
P.S. I have looked at the daysailer quarterly, and have not been able to get an accurate date from the information describing different model years.
David Britton (dlbritton-at-lucent.com)
