Hello,
I am new to Daysailer.org. I have a DS1 and am in need of some guidance. Overall the hull is in pretty good shape. I have removed the rub rail and am working on cleaning up the hull to start replacing all of the wood. (anyone with good pictures of how the trim around the cockpit is shaped and attached would be appreciated)
This forum has helped me to aquire floorboard plans and some guidance on rigging.
My biggest and probably most important issue right now is that I have noticed small cracks running along the outer edges of the deck along the cockpit. Does anyone know the best way to fix these. they do not appear to be structurally damaging but they clearly are deep into the coating of the hull.
I will post pictures as soon as I can.
Thank you all for your help and guidance.
Madison
