Transom Troubles
Well, it would seem that as soon as you finish one project another surfacing, uglier than the last.
I had just installed my wood work and was preparing to take the bout out to the lake tomorrow for the first sail. The sail I had intended to make each of the last three weeks. I went over the boat inspecting all the hardware and tightening. When I got to the brackets that hold the rudder on I noticed some screws were loose. I reached under the deck to get a wrench on the nuts there and found the board that sits against the hull almost completely and irretrievably rotten. Serious rot.
So I have some questions about fixing this. Not all the screws are in rotten wood. In the picture, the top two outer and bottom two outer screws are in "good" wood, while the top and bottom center screws are not. Essentially, everything that is "wrinkled" looking (paint) is rotten. Oddly, the majority of the rotten wood is in the center of the board. Not the edges, not the top or bottom. But the wood that is rotten is so soft that mostly its just the paint holding things together.
So, number one--could I sail with things like this over the next week or so while I make a new board in the evening? I'm betting it has been that way for a long time--it definitely didn't ALL happen over the winter. As a matter of fact, I may have bought it that way and just never noticed over the last several years. I'm sort of going crazy here. I had planned to be on the water at the beginning of last month!
Number two--does anyone have a suggestion for a specific species I should make it out of? I have a big piece of ash I am thinking about using. Would that be OK?
Number three--how is that board held in there and what's the best way to get the old one out without hurting the hull? I'm assuming that it is held in at the top and bottom with fiberglass tape and epoxy. Is that the fastening method?
My plan is to cut a board to shape, then cover in glass cloth and epoxy, then once dry, glass cloth and epoxy in place, then drill my screw holes from outside the transom so as to have them exactly where they had been. Should I cover the entire board with cloth and how many coats do you guys think are necessary? How many layers should I use to fasten it in place? Are we talking about buying another quart and a half of epoxy?
Thanks for the help...
