Outboard mounting, setting up reefing
Hi all
I ended up buying the 2.5 mercury outboard. When I set it on the stern, there is barely 1/2” of space for the screw clamps to tighten down even when fully loosened. My question is do I need some kind of wood to be mounted inside or outside of the stern where the outboard clamps on? So it clamps onto wood?
Right now it is just fiberglass.
I am also seriously considering doing the Texas 200 this year. I ordered a new main with 2 reef points from precision sails. The boat was never set up for reefing. So do I just install cheek blocks on the boom? What is the best cleat to use for the reefing line on the boom?. I have read that some jamb cleats can slip under load.I plan on buying the reef hook from D&R.
Any tips on installing the cheek blocks and making sure they are at the correct location?
Have read that if doing the Texas 200 you need to make sure you boat is bullet proof. What do I need to check and what can I do to make that happen? I did add new backing at stern where rudder mounts and glassed it in. It has the larger stays with turnbuckles, updated spreaders. I can be a paranoid person and part of me wants to go crazy and get a bunch of new hardware, gooseneck, etc...
Any tips or input would be great.
