How much clearance should there be between the centerboard and the inside of the trunk? In the attempts to achieve a good foil shape, I have added thickness to my CB. It's now about 1-1/8" maximum thickness. A couple layers of glass cloth and a little more filler should bring that dimension to about 1-3/16". Sticking a pair of inside calipers inside the trunk at several locations, the minimum inside dimension appears to be about 1-7/16".
So when everything is complete the clearance will turn out to be about 1/8" on either side. Is there a preferred measurement? I don't want to have the clearance too tight and risk jamming the board with debris.
Also, how fair is fair? What are the usual tolerances for the board profile? Now it is within +/- 1/16" of the planned cross-section according to my pattern. I'm getting tired of mixing toxic goop, and I am really really sick of sanding. Perfection seems to be pretty elusive, and anything, even a hunk of scrap plywood, will be an improvement over the original damaged state. As GreenLake pointed out in another thread, this boat is less than perfectly symmetrical.
As of a couple days ago, the CB weighed 29 lbs. I think I started with more than the class maximum weight of 25 lbs., and figure it will come out to 30 lbs. when all is said and done. I'm not racing, so who cares as long as there is not excessive strain on the fittings, etc. For crusing purposes, excess junk in the boat or excess beer consumption by skipper and crew can easily add more than 5 lbs.
