Connecting both uphaul and downhaul to spinnaker pole
Wed Dec 23, 2020 12:21 pm
by zeroready
My pole only has one eyestrap, how do I connect both uphaul and downhaul?
Re: Connecting both uphaul and downhaul to spinnaker pole
Wed Dec 23, 2020 1:24 pm
by tomodda
I use a snapshackle. I tied both up and downhaul to the shackle with a "halyard hitch" on each line. Relatively compact and I can easily take the pole off and lay it under my side bench. Then I just clip the shackle to the spinnaker ring on the mast and pull on the downhaul to stow the lines against the mast. When it's 'chute time, just clip the pole to the mast and the shackle to the pole and off we go!
Wed Dec 23, 2020 1:27 pm
by Fly4rfun
nevermind
read OP wrong, I dont have a spinnaker
Wed Dec 23, 2020 1:31 pm
by tomodda
Why use two when one will do? Just my thinking, besides buying extra shackles cuts into my beer money....
Wed Dec 23, 2020 2:00 pm
by zeroready
tomodda wrote:I use a snapshackle. I tied both up and downhaul to the shackle with a "halyard hitch" on each line. Relatively compact and I can easily take the pole off and lay it under my side bench. Then I just clip the shackle to the spinnaker ring on the mast and pull on the downhaul to stow the lines against the mast. When it's 'chute time, just clip the pole to the mast and the shackle to the pole and off we go!
Do you mean like this?
Is it not a bit awkward to have two lines pulling opposite directions from the same side of the pole?
Wed Dec 23, 2020 2:31 pm
by tomodda
Yes, like that. No, not awkward, the snapshackle gives the lines a bit of separation from the pole, just like in your photo, so nothing gets tangled. For what it may be worth, I don't use an uphaul line, instead I have a bungee cord to pull the pole up. I calibrated the length to just hold the weight of the pole + angle it upwards 20ish degrees. Works well for me. Only one line to pull (downhaul) and if I slack it off then the pole raises about as high as I'd ever want it.
Thu Dec 24, 2020 1:47 am
Single eyestrap - check
Bungee for uphaul - check
Life is good - waiting for 2020 to end
