Loose footed vs. what?
Greetings all,
My Daysailer was acquired without sails, and being a newbie and budget not allowing me to be choosey, I bought a generic mainsail and jib set, that are fairly close to the right size, but not exact. Once I get a little water under my keel, I'll cough up some $$$ for the right equipment.
I apologize in advance for not using all of the correct nautical terminology. You probably remember from when you started, how confusing all of these new words are...
Anyway, everything I've read about the DaySailer calls for a slot attachment to the boom (feeding the foot of the sail into the slot). Is that called something other than slot foot attachment?
The mainsail I acquired doesn't have a slot setup (on the foot); just attachment points at the tack and the clew which I've figured out from other posts must be what's referred to as Loose Footed. It also has a number of slugs that go into the mast slot which I think I already prefer over what I had expected to be a continuous slot rope feed. The slugs move very easily and raising/lowering the mainsail is fairly quick. Of course having not actually been in the water yet, I don't know if that's a good or bad thing.
So back to the boom, my questions are, other than how it's attached to the boom, what are the functional differences between a slot (is there another word for that attachment method) and a loose footed foot (is that redundant?).
Is one or the other easier to sail?
I guess I'll wait for answers to this before I expand into additional questions.
