by Guest » Thu Mar 22, 2001 12:53 pm
Hector, I didn't add any more flotation when I did this, but I added a deck across the stern of my DS II. It is very similar to the afterdeck on a DS I, but I think that mine covers moreof the cockpit (fore & aft). If you wish to add flotation, a "plank" of foam could be laid across the seats under this afterdeck, it would definitely seem like it would help to keep the transom higher while you bail out the water after recovering from a capsize.
Now, I'll yet you in on a little secret...unless you are racing, it is very easy to sail a DS without ever capsizing! If you sail with the mainsheet ALWAYS in your hand (use the camcleat to hold the tension) you can then release the sheet in time to prevent a capsize. I have been sailing my DS II for 5 seasons this way and have never come close to capsizing, I sail singlehanded (aka..no crew) most of the time and the area where I sail is known for it's strong afternoon winds. If the wind is strong, I often go out with just the mainsail, and even then I sometimes have to reef, but the DS can handle it and I have a good time!
