Attaching Cuddy Mast and Hiking Straps
Posted: Mon Apr 19, 1999 12:00 am
I need to attach a new cuddy mast section to the step and then to the bottom part of the mast hinge. There are holes already drilled in the step and likewise in the hinge. Should the mast be riveted or somehow bolted on? If riveted, should I use aluminum or stainless rivets? Thanks for any guidance.
I also want to attach hiking straps to the boat. I'm not sure where to attach these. There are two raised sections on the floor of the cockpit about a foot forward of the transom. Is this where the aft ends should be placed? Is the forward end attached to the cuddy bulkhead somewhere? If so, where and how far up? As with all DS IIs, there isn't a thwart amidships?
Thanks again....Pell
A Pell (pell-at-epix.net)
