by Adrift » Thu Jul 06, 2006 11:21 am
The spreaders stay on. I've seen a lot of variety, especially in the stern, as to what holds the mast. But I've never seen anyone take the spreaders off of a DS to trailer.
Sounds like my setup, and the one my father had, were somewhat like Sean's but not so high up.
I have a tabernacle on the mast and I leave the stub in the hull so I put a foam pad on that, and I have an extension on the trailer winch post (where foam stays put), and in the stern sits a PVC pipe (foam stays put). The mast is supported at those 3 points, leading edge up (if I recall correctly), and the spreaders drape to the deck with no issues.
My dad did not have a tabernacle, so his mast sat a tiny bit lower -- on a cushion on the cuddy, on an extension on the winch post, and a pole on the rudder gudgeons. Again, the spreaders lay nicely on deck.
Stays are neatly gathered to avoid kinks, and velcro straps or bungees hold it all together.
