by swiftsail » Mon May 28, 2007 2:25 pm
Well, the length of your spreaders will induce bend in your mast if your spreaders are free swinging and the length also effects the stability of your mast side to side. The amount of bend you want to induce depends on the cut of your sails.
As far as side to side, if your spreaders are to short as the wind gets above 10 knots the mast will start to bend to weather at the spreaders, if they are two long the mast will start to bend to leeward.
Different mast bend differently. Some of us run are spreaders fixed, and some of us free.
A good starting point for length 21 1/2"
DS 307 "Security Risk"
DS 14024 "Flight Risk"
Live Slow, Sail Fast
