by sunapeesailor » Tue Mar 25, 2008 8:44 pm
Hi Albanysailer -
Now in NH, but lived in the Albany area for several years. Lots of great sailing in the Albany area. Saratoga Lake is a great choice, good wind in the mid-afternoons. Brant Lake-about 1.5 hours North is another good choice. Solid sailing with a NE to SW lay the winds are usually from the WNW and allow for a great day of broad reach sailing end to end on the lake. As for the river, depends on where you're planning to sail...below Troy, it is tidal and you can help minimize current by sailing during an incoming tide...South of Albany, there are a couple of very broad areas that would make the current far less of an issue. By the time you're in Saugerties, the river is so wide that current will not be an issue...you can sail up or down river at will. As you move North of the Mohawk river, you'll find that you are in a more noticeable current, but it is still manageable with a reasonable amount of wind. The key consideration is the width of the river and you'll find the widest points South of Albany.
Fairwinds,
Bob
Tidewater, VA
