by Phill » Mon Mar 31, 2008 10:36 pm
If you have the masthead with two sheaves at the top, take one out and try your local home improvement store. The same thing happened to my original masthead years ago. I ended up purchasing a couple of Harken ball bearing sheaves that were to wide for the sheave box. After dremeling for hours to grind out more space, the Harkens worked ok. A few months later in a local version of Home Depot, in the cabinet, hinge, roller track area, I found some sheaves there that looked identical to the one that I had with a big ding. Much less expensive, and unless you are racing hard in mostly saltwater, I think the local ones would do fine.
Hope this helps. phill
