Hello all,
I've found some helpful info on trailer issues using the archive search, but I have a specific question I haven't seen a post on. The trailer that came with my '73 DSII has both bunkers (shortish ones in the rear) and rollers. I've heard different things about whether the rollers or the bunkers need to carry the most weight. When I jack up the bunkers so they carry the weight, they seem to make a long depression in the hull. When I lower them so that the rollers are carrying the most weight (which makes sense to me, as I suspect the fiberglass along the keel is heavier), the rollers, at least in one spot aft the cb, make little depressions or dimples. I'm sure these disappear when the boat is off the trailer, but since it lives on the trailer, I worry. Probably needlessly, since it's lived on its trailer for most of its life and there don't seem to be any serious problems.
But my question is about the roller that is located right under the centerboard. I'm not sure there should be a roller under the centerboard, or at least not one that takes much weight. What I think is happening is that the weight of the boat on the trailer is jamming the cb up into the trunk. The first time I try to lower it on each sail, it's the very devil to do. I have to put a good bit of strength into it, mostly by pulling on the wire itself rather than the line through the block. After that first drop, I can raise it and drop it fine without too much resistance.
So, I'm thinking I should lower that roller so that it holds the cb up, perhaps, but doesn't bear any weight of the boat. Or should I put the roller in a different place or do without one altogether where the cb is?
Ideas?
Thanks.
Phil
________
HAWAII MEDICAL MARIJUANA DISPENSARY
