Bilge water and self bailer question
I recently bought a previously owned DS II and put it in the water for about 30 minutes to test out the outboard motor and the centerboard controls.
I was surprised by the quantity of water that entered the boat up through the pipe where the long gone self=bailer was once mounted. I was also surprised by the water that poured out of the bilge drain at the base of the transom when I opened it on the trailer immediately after haul out. The water ran for probably 20 minutes. I've since observed that the self-bailer drain pipe
opens into the bilge as well to the self-bail venturi on the bottom of the hull. So it seems that water directly enters the bilge through the venturi via the self-bailer pipe. There are finger sized holes in the pipe sides and it appears to be designed that way but's corroded and I'm not sure. I'm ok with a manual plug in the self bailer pipe, but that doesn't seem to address the water entering the bilge from below. I'm sure I'm missing something. If someone can offer information or suggestions I'd appreciate it. I've been reading the DSII bilge/bail/leak posts, which are valuable but I'm still not understanding this yet. Thanks.
