Hatchboard Finish
PostPosted: Mon Sep 22, 2003 4:52 pm
by Guest
The hatchboards on my 1986 DS III seem to be teak, Can they be sanded down and polyurethaned
or must teak oil only be used? If so, is sanding needed first?
Peter Tenerowicz (peteten-at-hotmail.com)
PostPosted: Tue Sep 23, 2003 12:38 am
by Roger
My understanding of teak is that there are only two ways to treat it, with teak oil or leave it weather.
Having said that, how you proceed may depend on whether the wood is plywood with veneer, (as were mine) or solid teak. If the latter, you can sand down to new wood, then oil or let it weather. If it is ply (mine were in really bad shape) you might consider building from scratch. This was the option I took and made a single hatch board out of mahogany ply.
PostPosted: Tue Sep 23, 2003 6:35 pm
by Guest
Teak oil is fine for interior cabin work, but as exposed to weather without cover, it is completely useless. You have to redo it at least every three weeks and it looks horible. For a first class yachty look, sand lightly and apply three coats of polyurethane exterior varnish, labled as having a UV inhibitor. You may need to touch up in following years, but you should get at least 4 or 5 years out of it. Then strip it and start over. Too many coats and the stripping is unnecessary a little harder. I used the teak oil once in the last 40 years, but learned my lesson the hard way. What ever you do, I wouldn't let it go gray either.
John C. Jr. (ghampe-at-rcn.com)
PostPosted: Wed Sep 24, 2003 10:58 pm
by Guest
The cuddy boards are teak plywood, I have mine varnished. The previous 2 owners had painted them, but I sanded all the paint off the outside and varnished (4-6 coats initial, 2 light coats each Spring). I'm hoping to order a new set of the boards rhis Winter from Rudy at D&R Marine, they will be varnished.
Rod Johnson (daysailermanual-at-juno.com)
