by Roger » Sun Dec 14, 2003 1:09 pm
Short of replacing your pad or bunk system to rollers which makes launch and retrieval so easy, I would suggest replacing your pads with indoor/outdoor carpet... the astroturf variety. It is relatively cheap, slides the boat relatively easily when wet and you can staple it to the underside of your wooden pads. You can get small carpet pieces (6 x 8 feet)at your local hardware or automotive shop for under $20. I also think that the single most thing you can do to improve the support of your boat is to increase the length/area of your pads. This spreads the support resistance over a greater area of the hull, especially if you plan on trailering long distances. Remember to support your centerboard on a roller or cross member of your trailer so that the uphaul is not bearing the load of every bump on the highway.
