kokko wrote:Where do you get that many pop bottles? I think I will buy some 2" rigid insulation panels and cut them into long bricks. I calculated it will cost me $5/cubic foot.
Brad wrote:What I like about the plastic bottles is that they will offer far more floatation energy than foam or noodles. They won’t mold or smell or need to be replaced. They are cheap like me. The bottles will fit easily through a 6 inch deck port.
also forgot to mention that most of the bottles had collapsed to about half or less of their original full size
jpclowes wrote:In areas where there is an extreme temperature variation ... the expansion and contraction of the air in the bottles would over time colapse the bottles. The air leaks slowly out under high pressure on really hot days, and doesn't get replaced when it gets cold. The pressure to replace the cooling air wouldn't be as high.
