dannyb9 wrote:a 2.5 part system is kinda hard to visualize...
seandwyer wrote:This is all very interesting but I really am not grasping a lot of what is being said. Is the point here that the higher the ratio, the easier it is to operate the mainsheet, or is it just more effective in a mechanical way - or both?
seandwyer wrote:I use what is being called the Crosby. Once, a real racing sort of guy saw that on my boat and came over to change things around telling me what I was doing was ancient. He tied a loop through the transom blocks terminating in a figure 8 about a foot beneath the boom. The sheet fastened to the figure 8 then went down the boom as usual through the block on the end of the boom, then through the block mid boom to the block mounted on the center board locker. I sailed and it was fine but I noticed no difference at all - none! I'm trying t understand what a traveler on a DS1 would look like and then come to grips with what it can do - and if the sails are a little worn would a fella even notice?
Users browsing this forum: No registered users and 51 guests
