by GreenLake » Tue May 17, 2011 5:33 pm
You need to cover the distance from the launch bag, around the forestay, then to you block near the back of the boat all the way to the front of the cockpit.
That's basically twice the length of the boat, so for the DS, 32' would seem about right. If you're not sure, get 35' and be prepared to cut off any extra (is cheaper than the other way around).
The exact length also depends on how far back your blocks are mounted and how you are leading your sheets from there.
