Welcome to the forum! Looks like you have some work planned and have a question or two - you've definitely the right site.
I guess I'm a bit confused in trying to understand what you mean by "decking". The DS1 has four types of exposed wood parts. The coamings (there's a whole thread on finishing them in the DS1 forum), the thwarts (those are the pieces connecting seats to CB trunk) the little wooden "shelf" in the back (in some years) and the floor boards.
Some here think that you might be better off if you seal coamings and thwarts with epoxy (such as SystemThree Clear Coat) on
all sides (including inside edges of screw holes) before applying varnish or finish. Especially if you get lots of moisture cycling like in the PNW. (Not as strongly recommended if the boat will sit uncovered, because the UV protection from the Bristol finish may not protect the underlying epoxy well enough to reach the same extended lifetime of the total finish, but results with covered boats are good).
If you don't, then your chances that your finish will crack (and peel) are higher. Now Bristol might be more forgiving than other PU finishes (e.g. if it were a bit more flexible) something that I wouldn't know one way or another. If it is, then you might get decent life out of your finish. Read the discussion in the
thread on coamings -- you can definitely use the Bristol finish on top of epoxy saturated wood, if you decide to go there.
Even if you don't want to epoxy seal the whole coamings I would epoxy seal the inside of the screw holes with epoxy. They are the preferred location for moisture to be absorbed. I would also seal the screw holes going into the pieces of "backing" wood (called "carlins") under the side deck. That will slow any decay (dry rot) that may have started from water getting in there. The way to do that is to push some epoxy in there, wax your screw and tighten it while the epoxy is still wet. )The wax will let you remove the screw after the epoxy has hardened.)
To answer your specific question: definitely coat the coamings off the boat (see other thread on how to do this).
Now for any other wood that may be on your boat:
The shelf, if you have one in your transom, works the same way (and don't take it apart).
For the floor boards (they are the lattice like inserts between the seats and in the cuddy, if you have them), the issue is that in order to seal them you must take them apart so that each piece can be epoxy sealed on all six sides. You can then glue the pieces together, if you want, which would make the fasteners only decorative, instead of structural (you could just glue some nails in place for looks). If you still have original floor boards, they would probably be in a bit of iffy condition and could use a thorough restoration - or it could be someone tossed them long ago. (If you are without, you can skip the rest)
One problem where floor boards are different is that they can be submerged in water for extended periods. Even well sealed wood might have some small places, e.g. a scratch, that can "wick" moisture, and a lot of it, when immersed. Problem with epoxy coating is that this moisture can then never escape (it would eventually escape through Bristol Finish, but slowly). Even if you decide not to epoxy coat for that reason, you could still beef up the connection between slats and cross pieces by glueing them together. Epoxy glue is strong, but may fail over time if the wood gets really wet too often. However, the bond isn't critical to the health of the boat and you could reapply it after failure (and after drying the wood) - you'll probably find that the pieces don't fit tightly enough for real waterproof wood glue, so epoxy glue would represent a compromise. As before, whatever fasteners you have (e.g. bronze nails) would become mainly decorative, which means you could simply glue them in place with some epoxy if they holes they are in have loosened over time. (What I should have done in the first place, but I didn't have enough of the right info...).
Whether epoxy coated or not, you'd apply the finish after reassembling the floor boards (the epoxy glue would provided a seal for all the areas that you can't reach with the Bristol, while any exposed epoxy in the cracks would still get some UV protection).
