Boom Crutch
Boom Crutch
Postby bflosail » Fri Oct 04, 2013 10:00 am
In some of the photos in the gallery I have noticed a boom crutch made up of two pieces of wood made into an x to support the boom, how long does each piece of wood need to be ?
bflosail
Re: Boom Crutch
Postby rnlivingston » Fri Oct 04, 2013 10:33 am
I make mine 50 inches long. It puts the boom at a perfect height for my cover.
Roger Livingston
DS 6872
Mariner 4096
rnlivingston
Re: Boom Crutch
Postby rnlivingston » Fri Oct 04, 2013 10:56 am
I have a template of the boom crutch I make. It is a pdf so I cannot upload it. If you or anyone would like it, email me at rlivingston43@gmail.com.
Roger Livingston
DS 6872
Mariner 4096
rnlivingston
Re: Boom Crutch
Postby triathjohn » Fri Oct 04, 2013 2:03 pm
Some versions of the boat came (OEM) with the X boom crutch
1984 O'Day (Spindrift) Daysailer I 17'
# 11730
triathjohn
Re: Boom Crutch
Postby triathjohn » Fri Oct 04, 2013 2:07 pm
Does anyone have plans for a boom crutch that rides in the gudgeons
# 11730
triathjohn
Re: Boom Crutch
Postby GreenLake » Fri Oct 04, 2013 2:53 pm
The boom doesn't extend that far, is the only problem.
I have a mast support for trailering that rides in the gudgeons - it's basically a 1x4 with a notch on the top and pintles bolted to it.
To make that a boom crutch out of it, I would take a shorter 1x4 and angle it back from right above the transom to where it meets the end of the boom.
Then something to hold it at that angle. Perhaps a wedge of 3/4" plywood? Or another piece of 1x4 as a cross member...
Coat everything liberally with epoxy and resist the urge to varnish it, use any good spray paint to provide UV cover for the epoxy.
Users browsing this forum: No registered users and 71 guests
