by Guest » Sun Feb 18, 2001 11:21 pm
On the DS II the stock bailer was located in the shallow well at the aft end of the cockpit, on the early models it was an aluminum DePersia brand unit, later models had a plastic bailer that was basically the same as the one on a SUNFISH. There should be some evidence of the hole where this unit was originally mounted. Replacing the bailer is not hard, mine was broken when I bought the boat and I bought a new one from D&R Marine $34 at the time (now $40).
