drilling into fiberglass
Postby psness » Tue Jun 01, 2004 3:19 pm
I need to drill through the transom to install new gudgeons and mounting blocks. Anything unique or any tips on drilling through fiberglass? Will it crack away from the hole easily?
psness
Postby Roger » Tue Jun 01, 2004 11:46 pm
No special tricks. Just let up on the pressure a bit as you are about to break through. Drilling through fiberglass is just slightly less resistance that driling through wood. If you think it will chip the gelcoat, and you really don't want that, then put a piece of masking tape on the entry and exit and drill through that. It will reduce the chipping, although it tends to be fairly limited especially if you reduce the pressure. I think the core of the transom is wood, although I am not sure. I drilled part way in a couple of days ago to attach a swim ladder, but didn't seem to go deep enough to get sawdust.
Postby Guest » Wed Jun 02, 2004 3:18 pm
My 1974 DS II has a wood-cored transom. Wear eye protection and, if you have any sensitivity to epoxy or similar types of products, wear at least a curgical mask.
Bob (rowerw-at-comcast.ne)
