GreenLake wrote:On your question, I would be comfortable with the assumption that these are inseparable from their base. I looked around a bit to see whether anyone sells anything compatible, but didn't find anything..
GL - Thanks for the reply. Last fall I made a list of things to look at on the new boat before spring, took a lot of pictures, and made a number of measurements. I've been working through that list this winter, and my impression from last fall agrees with your assumption the the blocks and base are one piece.
I've attached some pictures of how the traveler is currently set up with these two blocks, plus a block (a Whale logo block) that is tied to the line that is the traveler, and then cleated under the tiller. I don't have a picture of my boat rigged, but the main sheet is tied into the becket on the aft block attached to the boom, then runs down to the traveler block (the whale logo block), back up to the block on the aft of the boom, then forward to another block down to block & cleat on the centerboard housing.
Also attached is a picture from a post on how the DS
Lollypop was rigged. Found this on our site, saved the picture, but at the moment can't find it again to point to. My boat seems to be rigged the same.
All of the three blocks in the existing traveler setup are very small, not 30mm. I was going to replace the block that handles the main sheet tied to the traveler line with a Ronstan Series 40 Orbit Single Block with Becket.
Assuming that the existing blocks / base would be replaced I was thinking of either the Ronstan 30mm or the 40mm stand up. Something like these
https://www.westmarine.com/buy/ronstan- ... cordNum=50 For the traveler line, I am looking at 6mm Bzzz line running through the two standup blocks and tied into the 40mm main sheet traveler block using an alpine butterfly loop knot.
https://www.animatedknots.com/alpine-bu ... -loop-knotWDYT?
