ElCapitan wrote:Hello everyone! I'm new to the forum but am a long time reader. I've been sailing my whole life, but largely due to the great community and wealth of info in this forum, I'm officially on the hunt for my first DS1!
Welcome to the forum!
ElCapitan wrote:I've got an appointment set to go see a boat about an hour away. Mostly everything seems good on the boat, but I pointed out to the seller that in one of the photos it's clear that there are no coamings. He said he got the boat that way and had no idea there were supposed to be any. Of course I will have to replace these (formerly a professional carpenter, thankfully!), But I'm worried that the side decks might have already been structurally compromised. Should I look for anything specific, or will damage be obvious if it's there? There are also no centerboard supports shown. Not sure if they are temporarily not in the boat or if they don't exist, but that also worries me that this boat may have hidden structural issues.
The picture you added looks very nice. You will see some triangular supports under the decks and there should be a piece of square wood also supporting the edge (called a carlin or carline). If you are already replacing the coamings, you might inspect these for dry rot and if found, replace these as well - they do tend to age. With all the supporting wood removed, it would be easy to support any weak spots in the laminate for the side decks,
Assuming there are any. You would foremost look for visible cracking in the gel-coat/paint. If the boat has recently been refinished, that won't help you, as much, of course. However, you may look from underneath; in the past, we you would have used a mirror, now the better way is taking a photo.
The missing thwarts (CB supports) are even easier to replace. Structural issues would show as cracks around the base of the CB trunk, where it meets the hull. Now, the DS1 is a single-hulled boat. Once you lift the floorboards you can access practically any part of the hull from the inside and apply a patch of fiberglass and epoxy resin should reinforcements be needed. These boats are eminently repairable and you seem to have the right set of skills already (If you haven't done fiberglass work, it's an easily acquired skill for someone with your background).
The boat gives the impression of being well cared for, it may be short of perfection, but I wouldn't rank it as "project boat". Yes, it needs a bit of work, but it does appear to be a major construction site.
ElCapitan wrote:Second question is price. The seller is asking $1500. Boat has paperwork, all working rigging, clean trailer w/ title, roller furling jib (my preference), and a 4 yr old 4hp outboard (a little oversized, as I've read, but I want a little kick here on the long island sound). ...!
I really don't like to give advice on price. Because everything is so readily fixable on these boats, I wouldn't expect even some obvious maintenance items to be cause for major price adjustments. It's more a question of whether you have multiple boats you are interested in or whether are willing to start with this boat where it's at to make it yours. Likewise, what the seller will accept depends on the situation more than on the boat.
Things that are harder to fix seem to be included (or you need to make sure), like masts and boom. In contrast to those, sails and running rigging are consumables - they need to be replaced at regular intervals anyway - only excellent/brand new or terrible/in tatters are conditions that would be reflected in the price -- anything in between is harder to account for; whether a new owner will replace sails and rigging in "average" condition sooner or later depends on too many factors from intended level of use to own sailing skills.
Title to boat and trailer is another one of those things that would be hard to "fix" if missing.
Finally, I see a decently sized outboard is included. That I would expect to be reflected in the asking price, because (unlike, say the trailer) it's easy to sell an outboard separately.
Let's say you sail this boat for 10 years. In that time you'll have some maintenance items, and you'll purchase at least one set of sails. And two sets of tires for the trailer, say. Something may break, and you may change the running rigging more to your personal taste (adding cleats / blocks / jib tracks as needed). Now add the purchase price to all of that and divide by 10. Does your budget run to that?
(In my case, maintaining a towing vehicle dwarfs everything
Would you be better off with a boat that was more of a project? Hold out for the "free" boat? Only you can decide that.
So, I can't tell you what to pay, but (very loosely) the asking price seems to be reasonably in the ballpark (depending on all the items and other conditions we can't see from a distance).
