Daysailer class rules
Postby Guest » Tue Dec 07, 1999 1:00 am
The hull has fairly large sunken places on the bottom starboard side. This is a DS II and these areas can not be easily accessed for repair. What are the class rules regarding adding some kind of stiffeners to the inside of the hull to remove these indentions. The shop manager said that it might be possible to use expandable foam to stiffen the hull in these locations. Any help with this problem would be appreciated.
Dick Andrews (dandrews-at-ozarkaircraftsystems.com)
