by GreenLake » Thu May 15, 2008 9:47 pm
I don't have plywood covers, but I have two covers that are some GFK material. They cover two largish holes in a GFK bulkhead above the front flotation tank. John, I'm assuming that's what you have, only with plywood parts.
My covers are each held in place by a bungee that is attached on their inside center and pulls them forward against the bulkhead. There are some shallow indentations in the cover that prevents them from sliding around, as long as something presses them against the openings.
The bungees run to a padeye on the top center of the flotation tank. They actually pull downwards at a slight angle, but that seems to not affect the covers; there appears to be enough forward pull to hold them.
I never put a lot of stuff in the front, so I don't worry about whether the bungees interfere with stowage - I guess they might in some circumstances.
