Green Lake,GreenLake wrote:OK.
Two questions remain. Polyethylene is hard to glue. How did you attach the strips? Screws?
The other question: What do you predict will happen when you get sand into the CB trunk?
My second boat is all polyethylene, and there's plenty of sand to go around where I launch it, so call me "experienced". In my case, it's chewed up the daggerboard somewhat ugly, as well as presumably the inside of the well. Added some friction as well, although I can't recall an instance of it being seriously stuck. Since it's a daggerboard you can really yank at it to try to free it, I think there's more force than you can apply easily to a DS CB.
Anyway, that's something I'd watch out for. If you don't launch from the beach, you should be fine.
Do I recall correctly that you are using Formica shims?swiftsail wrote:I've been using good old contact cement for gluing in my centerboard shims for years. I works great.
