by GreenLake » Wed Mar 17, 2010 1:24 am
There are two general patterns. Two section floor boards and three section floorboards. The two section ones take fewer but shorter parts, but extra steps assembling. After that, they are said to be easier to get in and out (mine are the two section kind and I think they are fine).
The pattern Brad linked is a good start. Make sure you make some sort of template from stiff cardboard or something. That's to ensure that you get the measurements right.
The "feet" need to be adjusted (filed down) to fit the boat, so the floors are level. On mine, the feet (cross members) appear to be made from a softer wood than the slats. That way, they don't grind into the hull. The coamings on my DS were made from mahogany, which sanded to a nice pinkish hue, but the slats on the floors looked more yellowish when sanded. So I'm not sure what the wood is.
Finishing - you have several choices:
Oil - easy to put on, needs frequent touch ups, but those should be easy, as you don't sand or need to take off any old layers.
Varnish - needs more prep, can last longer. At some point you need to take old layers off by sanding. Varnish and PU need multiple coats, 6-8.
Polyurethane with cross linker - very hard, lasts several seasons. Tricky to recoat with good adhesion. Hardness makes it tough to get off if you need to recoat.
Epoxy sealing of all wood, then PU overcoat (for UV protection) - thicker film, wood no longer expands, so PU lasts even longer than on bare wood (should be no cracking).
If you are constantly puttering around your boat, and/or keep it exposed, then oil is the best. Just wipe down your boards with fresh oil several times a season.
PU is fine under cover for multiple seasons even if outdoors, sand well before recoating.
Epoxy promises to be the most durable, looks great because of the depth of coat, but I don't have multi-season experience with it. Epoxy coating should have two other effects. As it blocks water and vapor, it should allow the use of wood that's less moisture resistant. And it should harden the surface, perhaps allowing a lesser grade of wood there as well.
Finally, nothing prevents you from using oil-based stains one would use for deck or patio furniture. Those are similar to the pure oils, but if well maintained, should work - esp. if you keep a dry bilge.
As you can see, there simply isn't the "one way".
Good luck!
