by GreenLake » Fri Jun 18, 2010 6:14 pm
I've had to upgrade the screws to a longer size, possibly also bigger, not sure. They screw into a bit of wood that's encased loosely in fiberglass. Technically, that kind of support for the side deck is called a "carlin". The carlins in the DS are subject to rot, because once they get wet, they don't dry out well because of the fiberglass, but the fiberglass does a poor job of keeping them dry in the first place. Hence, you will find that your screws may not hold well at the original size.
The design calls for oval head wood-screws with finish washers. Stainless, of course. These are the washers that are like a half-donut.
The best thing would be for you to test this with any old wood-screw, or rather several of different dimensions, but of course shorter than the thickness of the coamings and carlins combined, which you can easily guesstimate once you are at your boat.
That way you can also tell quickly whether some of the holes have gone softer than others, and therefore need bigger screws.
Finally, you could see whether you need to restore the carlins, either by replacing, or by treating them. One system for restoring partially rotted wood is the End Rot kit from System Three. It consists of a Borax-based solution to kill fungus, followed by a very thin, penetrating epoxy. This system is a good choice for treating localized rot, like around screw holes. If the wood is in good shape, you should still seal the screw holes with epoxy, because that's one place where water gets in.
Also, the original design calls for some sort of gasket material between deck and coaming. That was missing on my boat, and I didn't find out about it until after I had remounted the refinished coamings. There's some discussion of that in the repair or DS1 forum, just search.
Good luck.
