I've been reading up on sandwich deck repair in some forums not likely visited by people here. I can distill what I learned as follows:
- it's work, but can be done successfully
- careful evaluation of the condition is needed
- after you've localized the damage, radical cure is best
- attempts to dry out wet core are hopeless -> remove it
(although balsa is claimed to have the best chance in drying,
if fully uncovered).
- you might be able to cut out and reuse the top laminate
(tool of choice: Fein Multimaster)
- opinions are divided on whether to use balsa again or foam
If you have a crack in the bottom of the hull, that obviously needs to be fixed to make sure you don't have any water coming in.
Looks like a winter project.
