by seandwyer » Sat Oct 02, 2010 10:31 am
As far as the spreaders from D&R let me just say that I think they are worth it. About three weeks ago I was attempting to raise the mast by myself during a really windy morning. I had my sister and her husband drive about an hour to meet me and although it was too windy for me to feel safe (20 to 25) I was determined to go out - maybe just use the jib to go down wind for a while then motor back. Anyway, just as I was raising the mast a really big gust came up - really strong. It sort of got me off my bearings and the mast began to tilt over to the port side - in a panic I pushed hard to center the mast and raise it - all the while wondering how the wind was exerting such force on the mast as to make me struggle so much with it. Well, it wasn't the wind - (that was a coincidence that probably did make me begin to go sideways), the the starboard stay had slipped through the spreader a lot somehow and there wasn't enough slack to raise the mast. I looked up and saw the spreader dangling from the stay, still pinned to the bracket. In my panic I had broken every rivet and completely detached the bracket from the mast - but in all that stress, the spreader wasn't even bent - not even a little. So then I got to drive 45 minutes to a hardware store for a rivet gun - but oh well.
On another note, a friend of mine has some homemade spreaders that work great on his DS1. I've made a few spreaders out of aluminum stock but the stuff at home depot is just too soft. He made his out of stainless, has had them for years and they work great.
Greenlake, you might try as he did - go to a metal scrap yard and see what kind of stainless stock they have. You may find exactly the diameter you need - then its just a mater of drilling a hole for the pin - at the other end I used a 4" grinder cutting wheel and it seems to be the perfect thickness to accept the stay. I think stainless sounds great if you are going to make them - but if not, the ones from D&R are definitely worth it.
Sean
DS1 - 3203
