cleat table
cleat table
Postby jdoorly » Sat Oct 30, 2010 12:02 am
I like to position myself outboard of the mainsheet which made the jib sheet cleats on the centerboard just out of reach. And I needed to mount some cleats for the DRS sheets. So I designed this table that straddles the centerboard box. It came out real sturdy: The legs are a very good fit to the CB box and I layed in a bead of 3M 5200 on the contact surfaces, plus screwing it into the deck. I've got pouches that attach to the table sides to hold the sheets, on the sewing to do list. I put the compass on the table too, and it's a good spot for it if you use the lubber lines. I'm not sure how to remove the old cleat wedges, their stuck on pretty good and I don't want destroy the glass underneath!
897
use a chisel
Postby Roger » Sat Oct 30, 2010 7:42 pm
The teak will break off before the gelcoat. I used a wood chisel on the surface and a goodthump removed the teak riser. I had to remove slivers that slip off from the riser, but the gelcoat underneath was unharmed. Some 320+ grit sandpaper may be needed to remove any residual adhesive.
Postby jdoorly » Sat Oct 30, 2010 9:46 pm
Thanks Roger, I feel more confident about removing the wedges now.
Postby algonquin » Sun Oct 31, 2010 11:18 pm
I like your table design. Makes a good spot for your compass as well as your cam cleats. The mods you have made to your boat give it a nice “salty” look. Brad
"Feather" DS1 #818
algonquin
Postby ctenidae » Mon Nov 01, 2010 10:01 am
Looks nice.
I don't see any cupholders, though.
Formerly 28 cents
DS1 1114
ctenidae
Postby jdoorly » Thu Nov 04, 2010 10:49 pm
Thanks guys! Cup holders, hmmm, good idea!
