by GreenLake » Mon May 16, 2011 3:42 am
Yep, the windage is there, and it's uneven. But by having your rudder down and the CB up, the rudder becomes the pivot around which the wind will turn the boat. In a way, it's almost worse than without the rudder.
I suspect that with CB down and rudder used to steer (as opposed to fixing it amidships) you should be able to keep the DS into the wind while rowing - up to some limiting wind speed that's higher than w/o the CB.
I tried motoring upwind in about 10kn wind once with a small trolling motor and found that it was not only slow but difficult keeping the boat upwind and that trying to go for an angled course was hopeless. Don't recall whether the CB was down at that point.
I then raised the jib only (and CB must have come down) but you can't sail a DS upwind with just a jib in those conditions. So I added the thrust of the trolling motor, angled sideways, to mimic the turning force of the main. That did the trick and allowed me to tack.
(Reason I didn't raise the main was just like your case - moving the boat a few 100 ft. between docks, single handed and not wanting to bother.)
