I have heard that if you buy a DS that comes with original sails it won't have a sailnumber. My DSII doesn't have a sailnumber either so I think it has its original.
My DSII has a serial number of XDY12715E484. The sail number is 12715. I think the digits in the center are the number, hence the older boats have a numerically smaller sail number.
The sail number as it was explained to me is optional. Paul's set could be original but also could be replacements. His boat is an 1984 by its s/n. Do you have a sail bag? Look on it as it may have a number that matches your s/n or if like my 1974 no it doesn't and niether do the main or jib match.The main sail I have now has a orange stripe about 2/3 of the way up with the DS in white sewn there.My jib has the mylar window in it also.
The sail number as it was explained to me is optional. Paul's set could be original but also could be replacements. His boat was built in 1984 by its s/n. Do you have a sail bag? Look on it as it may have a number that matches your s/n or if like my 1974, no it doesn't and niether do the main or jib match.The main sail I have now has a orange stripe about 2/3 of the way up with the DS in white sewn there, no numbers. My jib has the mylar window in it also.
My Spindrift DS1 did not come from the factory w/ sail numbers either, only the "DS". I think most people simply add the numbers to their sails when and if they start racing. That's what I did...$2 per number at my local sail loft. They stick on just like a decal.
I've got XDYD65600473. The DS on the mainsail (a well aged ODay made by Neil Pryde) is red like the hull, but the 6560 (stitched on) is black. Original? Also, do I read the hull number as zero-473 or oh-473?
Day Sailer Hul Id Number; (only applies to boats 1973 model year and later) XDY = O'Day XXXXX = hull/sail # mine is 10201 M = model year format 79-E= model year and month (A = August, B = Sept., C= Oct. etc) mine was built Dec 1978. XDYxxxxxMYY-(A,B,C, etc) for 1984 and newer; date was MMYY format XDYxxxxxMMYY
