Have a few questions on rigging and coamings. Can anybody recommend good turn buckles that are easy to adjust for the shrouds. The ones I have now are the type with six or seven holes that you pin in the position you want. The problem is that the stays are slightly different length and one side is always tigher than the other with no way to adjust the tension equally.
I would like to get some measurements of some unaltered coamings. I have to fabricate new ones as my original ones are decayed and hacked all to pieces. The measurements I really need are the distance the original coaming rises above the side deck level and how wide the coaming should be toward the stern of the boat. I am going to cut the front part of the new coaming down to accomodate hiking room for two people. Yeah, I want the boat to look pretty and as close to original as possible, before I beat it up racing. I may be slow, but want to look good while everyone passes by!!!
