Phill wrote:
Perhaps a dremel with a cutoff wheel could shorten the bolts that hold the forward check blocks. Those things look like a nice thigh scratch makers if you get too far forward or slip durning a manouver.
phill
Good Idea. Actually I meant to do that and forgot. I'll do that this week.
Phill wrote:You might try putting the fairleads on the coaming futher forward, like in Caldens picture at the beginning of this thread. For beating this will put a little more leech tension on the jib and keep the top from twisting too much.
phill
I usually adjust them for wind speed. Usually the first thing I do when I race is go out and adjust them so the tell-tails, up and down the sail, all break at about the same time. If I remember correctly, it is forward for heavier air, aft for lighter. To be honest, they are there simply because that was where that point was the last time I sailed last fall.
Phill wrote:
Very nice work and a great idea.
phill
Thanks! Actually, I have to give credit to Ken Seamon, who I copied it from. He had (has, I haven't seen his boat in a few years,) his cleats there. The setup seemed to make sense, and I was looking for a solution for my crew.
J .P. Clowes
DSI 14083
