Cutting Inspection Holes
Postby BigGrover » Tue May 20, 2008 11:58 am
After reading some of the posts here about cutting inspection holes in the seats to check the flotation I was thinking I might need to do the same for one I am considering purchasing. Where is the best location to make the cuts and install the inpection ports?
BigGrover
Postby John Stevens » Tue May 20, 2008 8:02 pm
I just cut mine, I made them in the forward end of the seats.
John Stevens
Cutouts
Postby MarcCram » Wed May 21, 2008 11:50 pm
Here is where I made my openings, I made the first cut on the starboard seat with just over a 4" diameter hole. After realizing that 4" isn't enough width to remove the foam I had to enlarge that one hole (the reason it isn't as pretty as the other two). Also, the hull was in really bad shape when I took these pictures.
[thumb=620] [thumb=621] [thumb=622]
I will post pictures of the Beckson inspection ports mocked-up when I find them.
Marc
MarcCram
Postby John Stevens » Thu May 22, 2008 8:13 am
Marc,
Nice shots. In the "bow" picture, is the keelson open to the bow? I cut my hole but it's solid foam so I can't get my hand in there.
I'm wondering if the water runs down in that keelson or stops in the bow?
Also, did you cut a drain hole in that keelson? If so, where?
TIA,
John Stevens
Inspection Ports
Postby MarcCram » Sat May 24, 2008 12:36 pm
John,
The keelson is open to the bow flotation chamber, it is one smooth molded piece. When I bought the boat it had a drain plug hole drilled on the starboard side of the keelson just ahead of the centerboard trunk. The same size plug used in the seat drains was used here (I don't know if all o'day built DS1's with fiberglass seats have these drains.)
Here's a picture to better describe the location.
[thumb=624]
Cheers!
Marc
MarcCram
Postby algonquin » Sat May 24, 2008 10:56 pm
I have a DS1 built in 1963 that has fiberglass seats and no keelson drain plug. The keelson stops short of reaching the forward flotation compartment bulkhead by a few inches. Water is free to run in and out at that point. Brad
"Feather" DS1 #818
algonquin
Postby John Stevens » Wed May 28, 2008 3:18 pm
Thanks for the picture. My keelson goes to the front flotation area but doesn't meet the centerboard cover. I put the plug on the starboard side just a bit further up.
John Stevens
Postby navahoIII » Mon Jun 02, 2008 2:00 pm
algonquin,
My keelson is like yours (open and stops short of forward flotation compartment). The boat is also circa 1963. How much of a problem is it if water is there and where does it come from -- a leaky centerboard handle? If it were sealed off in front would water get in there anyway? What purpose does a keelson serve?
Thanks.
Navo
navahoIII
